What goes in the hole above the on/off switch on a SA?
SteveNH
04-29-2008 06:43:30
On my "48 Super A "Dash" I have an ammeter on the left, the L/H/B/D on the right and in bewteen those two I have two smaller holes, the on/off switch that goes to the magneto is in the lower hole and there is nothing in the hole above it. What goes there? It is the same size hole as the on/off switch.
Thanks
Steve
Hugh Mackay
04-29-2008 14:33:41
 Re: What goes in the hole above the on/off switch on a SA? in reply to SteveNH, 04-29-2008 06:43:30
Steve: The fuse holders are still available at CaseIH. I bought one last fall, and for the price you can"t make two other stops 5 miles out of the way.
Gene-AL
04-29-2008 08:11:44
Scotty is right - fuse holder for lights circuit.
With a magneto tractor, one fuse terminal goes to the Ammeter (generator side), the other terminal feeds the light switch. The correct fuse is a SFE 20A. Radio Shack may have replacement fuse holders.
ScottyHOMEy
04-29-2008 06:51:06
Sounds like a hole for a fuse-holder.
Is your light switch three- or four-position? Any sign of having been re-wired?
SteveNH
04-29-2008 06:55:57
 Re: What goes in the hole above the on/off switch on a SA? in reply to ScottyHOMEy, 04-29-2008 06:51:06
Its got a non working 4 position switch. I am in the process of rewiring it since only some of the wires are present and not cut off. I am thinking of getting a used 3 position instead since I have a voltage regulator now instead of the cut-off relay so I don't need the l/h positions on the switch.
