W-6 Plug's,
Farmall kirk,
04-16-2008 09:05:16
I saw some plug wires on a parts site for farmalls and all i see is the chincy looking wires and you cut to lentgh whatever they are and then put the cap on the plug,
I have the old push type caps on mine and they look like they dont really hold that good to the plug, and if they get loose they wouldnt work at all,
autolite plugs are alot better than champion's,
they sem to have a better heat reange than the champion's and are made alot better, as you can see by just looking at them,
What autolite plugs go in my W-6 anyway?
F, K.
Andy Motteberg
04-17-2008 19:29:56
 Re: W-6 Plug's, in reply to Farmall kirk,, 04-16-2008 09:05:16
I recommend Autolite 3116, the Autolite plugs are good, but the Champions are also good.
glennster
04-16-2008 10:23:21
you can run either autolite 386 or 3116 plugs. the 3116 are non resistor plugs, better if you have a magneto.
RustyFarmall
04-16-2008 10:49:23
 Re: W-6 Plug's, in reply to glennster, 04-16-2008 10:23:21
Or Autolite 388. Even hotter than the 386.
iowa 100
04-16-2008 09:23:29
oops, replied to wrong post
iowa100
04-16-2008 09:20:02
gaskets are also shims, use however many needed.
