This chicken looks and quacks like a duck
Peculiar Farmer
03-17-2008 14:31:17
Having no luck getting a replacement shaft for the distributor on my MD. It has a hydraulic pump mounted on it and I posted a picture on 3/10. Everybody says because its a verticle distributor it has to be a Delco however it has the IH part number cast in the side and the local salvage yard where I got the gear for the bottom said it was an IH shaft. Everything except the gear on the end looks like the parts breakdown on CNH website. Is it possible to put Delco guts in and IH distributor?
Janicholson
03-18-2008 09:16:36
 Re: This chicken looks and quacks like a duck in reply to Peculiar Farmer, 03-17-2008 14:31:17
There is a new post for you on the forum. JimN
glennster
03-17-2008 14:43:10
i may have a vertical delco in the barn somewhere, out of a gas m. i'll see if it looks like the i-h distributor. i would think they are pretty close. have you tried bates corporation in bourbon indiana for a distributor? they are a large i-h salvage yard and have rebuilt parts too.
Peculiar Farmer
03-17-2008 17:37:10
 Re: This chicken looks and quacks like a duck in reply to glennster, 03-17-2008 14:43:10
I just talked to Bates this afternoon which prompted the post. The number cast into the distributor is 353898R1. The gear I got came off an Allis WD45 Delco and is identical to the worn one.
