H hand crank disassembly
neblinc
03-10-2008 07:17:51
Well after cleaning off the crud I could finally see how this thing came apart.
Randy
third party image
neblinc
03-11-2008 05:40:50
 Re: H hand crank disassembly in reply to neblinc, 03-10-2008 07:17:51
I had the bolster off when I removed this one. If you can get in there and remove that snap ring and get that piece that covers the retaining pin off it might come out.
I had to drive it out from the front by hitting the shaft to get that cover piece loose, you won't be able to do that while the bolster is still mounted, it will hit the crankshaft.
Randy
BobinOhio
03-10-2008 15:13:13
I need to remove this assembly on my H too because the piece with the groove cut in it that turns the crankshaft is rounded out. Can it be removed from the bottom without taking the front bolster off? Do I just drive the pin out and it will come apart? Any suggestions on removing it? Thanks Bob
Allan In NE
03-10-2008 15:25:38
 Re: H hand crank disassembly in reply to BobinOhio, 03-10-2008 15:13:13
Bob,
I used a power chiesel on mine and she came right out of there..... ..in pieces.
Allan
Andy Motteberg
03-10-2008 10:01:54
You got it looking real nice!
