60-L Plow
mkirsch
02-12-2008 08:27:43
I just bought what I believe is a 60-L trailer plow.
From looking at the operator's manual, it's different from either the "two-three" bottom version and the "three-four" bottom version of the 60.
Why did IH produce three different versions of the 60 plow?
What is the signifigance of the 60-L version? The frame design is somewhat different from either of the other versions.
mkirsch
02-14-2008 06:10:42
 Re: 60-L Plow in reply to gene bender, 02-12-2008 08:27:43
Thanks Chuck. I've got both a 60 and a 70 manual. Read the 60 manual cover to cover, and only see mention of "60-L" in three places:
1. "This manual covers..."
2. Random picture of a three-two bottom #60 plow, with three bottoms, mislabeled as "60-L"
3. Top view of a 60-L plow.
Careful comparison between the four-three bottom #60 and the three bottom 60-L led me to the same conclusion: The 60-L is a three bottom plow using the four-three bottom frame design. Cool.
Chuck46
02-12-2008 20:15:39
 Re: 60-L Plow in reply to mkirsch, 02-12-2008 08:27:43
Mkirsch, I have done a lot of work with both 60 and 70 plows but have no idea what the L is. Can you describe it? Chuck
Chuck46
02-12-2008 20:32:02
 Re: 60-L Plow in reply to Chuck46, 02-12-2008 20:15:39
Mkirsch, After making my first post I dug out a manual for a model 70, low and behold I found it. The three furrow plow can be reduced to a two and the four furrow can be reduced to a three. If they have been reduced so all frame members come all the way to the front of the plow then they have the L designation. I guess if all else fails read the instructions. Good luck, Chuck
