Farmall M hand crank shaft
Zach Bouchard
01-21-2008 20:53:46
How do I remove the front shaft starter shaft on a Farmall M? I heard the ring on the front of the tube that turns the engine comes off and there is a pin under that. How do I get the ring off? Is it threaded? I only need to replace the shaft that comes out of the bolster. I was told i have to take the whole bolster assembly off, but I think they thought I was talking about the whole starter assembly.
kfox
01-22-2008 06:37:42
 Re: Farmall M hand crank shaft in reply to Zach Bouchard, 01-21-2008 20:53:46
I think you will need to remove the bolster to get the front shaft out. At least on the H you do. The whole gizmo comes out the rear of the bolster. The flanged sheet metal collar is held in place by a big coil spring on the outside of the starter and you slide the collar to the rear compressing the spring to remove the pin.
ken
RustyFarmall
01-22-2008 07:41:41
 Re: Farmall M hand crank shaft in reply to kfox, 01-22-2008 06:37:42
Correct. There just isn't enough room between the bolster and the engine. you've got to remove the entire front bolster.
