656 Wide Front End
skyharborcowboy
01-20-2008 14:19:29
Now that I have the hydraulics sorted out I want to work on the front end. The ball joints on the tie-rods are way beyond shot. Is the dealer the only source for them or is there an equivalent that would be less expensive? The dealer told me they could only get them as a complete tie-rod assembly.
Joe
skyharborcowboy
01-24-2008 19:07:13
 Re: 656 Wide Front End in reply to georgeky, 01-20-2008 14:19:29
Allan In NE said: (quoted from post at 17:43:01 01/20/08) Outer tie rods are something like $29 at any dealer or vender. Inners aren't much worse. Common as hen's teeth.
Be sure and get the long ones if you plan on spreadin' 'er out. Somebody cheated me on these. :>(
Also, you might want to look at that center pivot. They wear over time and need the pin/bushings tended to.
Allan
<img src="http://www.rieckesbaysidegallery.com/programfiles/talers/tieroddone.JPG">
Allan,
I went back to the dealer today to try to buy just the rod ends. We found the ones I need listed under the "Farmall" J-20 section of the CASEIH parts catalog.
The outboard ones are $68.00 and the inboards are $48.00 a piece. If you guys can clue me in where you are getting them so cheap I would appreciate it!
Thanks,
Joe
359984R92 ROD ROD ASSY, tie $68.00
384006R91 END ROD ASSY, tie, RH thread $48.00
Lynn Davis
01-21-2008 11:42:19
 Re: 656 Wide Front End in reply to skyharborcowboy, 01-20-2008 14:19:29
I think you've had plenty answers on locating tie rods. But just to throw my .02 in I have replaced several outers by reusing a tie rod end from an automotive appl not worn to much for the tractor and cut and weld.
Steven f/AZ
01-20-2008 16:05:10
Our local dealer gets a lot of stuff from Hy-Capacity that is a good replacement for IH parts at a lower cost. Don't know for sure if they have tie rod ends or not...
MN Rick
01-20-2008 15:53:04
Just click "Tractor Parts" over to the left and you are in business.
Bob Price
01-20-2008 14:46:07
There are several companies that specialize in just IH salvaged parts. Try Bates Corp. 800.248.2955. They have helped me several times. They are in Indiana.
Allan In NE
01-20-2008 14:43:01
Allan
third party image
jeffnc
01-20-2008 18:31:47
 Re: 656 Wide Front End in reply to Allan In NE, 01-20-2008 14:43:01
allan, what is the easiest way to spread or narrow a factory wide front that is stubborn?
Allan In NE
01-20-2008 18:46:34
 Re: 656 Wide Front End in reply to jeffnc, 01-20-2008 18:31:47
Just about any way you can make it work.
Those badly stuck ones, I use pure brute power and pull 'em apart with two other tractors.
Lessor stuck units, a man can get away with penetrating oil, heat and a big hammer.
Heard of fellas loosening the bolts and driving them around for a week with just the pins holding the pipes. The "jarring" seems to help break 'em loose.
Once they are loose tho, I really grease and lube 'em up so it won't happen again.
Allan
RustyFarmall
01-20-2008 14:40:32
It depends on how those tie rods and tie rod ends are made. Some tie rods are built so the just the end, or ball joint is replaceable, and on others the tie rod end is an integral part of the tie rod itself, and you have no choice but to replace the assembly. Your dealer is NOT the only source.
Larry NCKS
01-20-2008 14:27:24
 Re: 656 Wide Front End in reply to J. Klein Rot, 01-20-2008 14:19:29
good question I been wondering the same thing on my 70 Hydro. should be the same part # maybe someone will know the answer.
