544 power steering leak
Tim (NY)
01-10-2008 14:46:46
I have a leak in my power steering ram where it meets the junction block with the hoses. I've replaced the o-ring a couple of times, with the same result. The o-ring doesn't seem to seat properly, it squeezes out one side. Has anyone else had this problem, and what do I need to do?
Willie Zepeda
01-10-2008 16:00:37
 Re: 544 power steering leak in reply to Tim (NY), 01-10-2008 14:46:46
Have you tried using brass flat washers like the ones you see on automotive brake lines that connect to the rotor?
