886 fuel Injection ??
Matt NC
12-29-2007 13:12:36
Went out to the 886 & tried to start it today, usually she just pops right off. No go today. Ended up cracking the fuel lines at the injectors & bleeding them before it would start. It has sat for two months.
Don't see where a leaking fuel line to one of the injectors would keep it from starting. I would think it would miss on that cylinder. Any ideas out there?
Thanks,
Matt
Matt-NC
12-30-2007 08:07:39
 Re: 886 fuel Injection ?? in reply to Matt NC, 12-29-2007 13:12:36
Thanks guys, I'll take a look at those.
Fromjb2
12-30-2007 06:43:47
Hi Matt, if it is a Bosch injection pump usually there is a check valve in the pump to prevent the return line from leaking back draining the injectors. Maybe the check valve is sticking open.
JimB
minnesota red
12-29-2007 20:46:01
i would check for leaks in the return lines.
