5th gear lock out?
rdb
12-06-2007 17:00:10
Hey, i have a 42 Farmall H that orginally came with steel wheels. It has been converted to rubber and it will not shift into 5th gear. In a book i have seen where they locked 5th gear out. How do you unlock this gear?
Thanks
RockyMO
12-06-2007 18:54:55
 Re: 5th gear lock out? in reply to rdb, 12-06-2007 17:00:10
I am a new H owner that just received my shop manual and owners manual today from this website. The owners manual just happens to show exactly what your looking for. Here is a picture and a description. The book states to remove the lockout screw and replace it with a 3/8 X 3/4 inch cap screw.
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Massey Ferguson 2135
Oliver HG
Real tractors have tracks
and a farmall H
third party image
Andy Motteberg
12-06-2007 17:23:12
The 5th gear lock bolt is on top the transmission next to the steering shaft support and fuel tank support. You do not need to remove it, you can just loosen it, or remove it and put in a very short bolt. After you do this, your 5th gear will work.
Buzzman72
12-06-2007 17:17:38
About 20 years ago Dad was servicing an H on steel, and it had the 5th gear lockout. I don't recall exactly, but I believe it was either a headless bolt or a pin that was threaded into the top case, which prevented the 5th gear shift rail from sliding and engaging 5th gear.
I believe Dad said the way to get it out was to cut a slot in the end, and use a "two-fisted" screwdriver to remove it...then put a much shorter bolt in to fill the hole.
Anybody else remember differently?
