Farmall A temp gauge
bigr
11-11-2007 05:34:00
I know the A's didn't come with temp gauges and SA's did. Can I put a SA temp gauge on my A and if I can where does the probe screw into? Thanks!
Younger
11-12-2007 05:34:54
 Re: Farmall A temp gauge in reply to bigr, 11-11-2007 05:34:00
My manual says "Tractors with gasoline engines are not regularly equipped with this feature"
n9lhm
11-11-2007 09:38:44
On my A (no water pump) I drilled and tapped a hole in the upper water elbow to screw the gauge sensor into. I didn"t want to put it in the lower elbow like original since it will never read anything but cold there if you don"t have radiator shutters.
Robert Ba
11-11-2007 07:17:19
You may want to verify this but I think you can get a upper water neck (where upper radiator hose attaches) from a tractor like Super C which has the connection for the temperature probe located in the upper water neck. hopes this helps. I am sure there are people in the dicussion forum that can verify.
Make sure donor tractor had water pump
Red Dave
11-11-2007 10:05:52
 Re: Farmall A temp gauge in reply to Robert Ba, 11-11-2007 07:17:19
A Super C upper water outlet will not fit on an A. They are a different size, length and angle.
I've tried it :(
NDS
11-11-2007 06:12:59
Many As (most dual fuel tractors) have temperature guage, the sensing bulb screws into bottom radiator hose elbow. Tractors that did not come with temperature guage usually do not have hole drilled and tapped for bulb.
