Farmall Super C Alternator
JohnG(TX)
09-28-2007 10:25:26
Is there anything special about installing a GM 10SI on a Super C? I put one on my M and had a little fun with the brackets. I am hoping that it will fit on the original mounting bracket and adjust with the original belt.
Keith-OR
09-29-2007 19:32:07
 Re: Farmall Super C Alternator in reply to JohnG(TX), 09-28-2007 10:25:26
OK John, here is picture's of the other mount I've made to put GM 10SI on a Farmall SC...HTH
Keith & Shawn
third party image
third party image
third party image
El Toro
09-28-2007 15:05:27
A rebuilt Hytachi alternator from Napa is around
$50.00. Hal
PS: Part number is 2138130.
Keith-OR
09-28-2007 14:53:16
Hitachi might fit the mount, BUT how you going to get the pulley to line up with fan pulley, has the SC generator has a pulley that extents out from the front of generator 2 1/4 inches to center of pulley.
There is a couple of ways to mount GM 10si on SC.
1. drill and tap armature to allow installation of the SC gen. pulley
2. Make another mount so that you can move the alternater forward as to line up pulleys.
I will see if I can get some pictures of several ways that I have to mount alternator on a SC
Keith & Shawn
Drilling and taping armature shaft and using SC generator pulley
third party image
Mount::
third party image
dcw
09-28-2007 12:38:47
I can't believe as patriotic a folks as Americans are that you'd put a Japanese alternator on an American tractor.Use an alt off an S-10 or a cavalier,easy to mount,puts out more amperage,and is readily available.
It too may be made in Japan,but I should think Delco-Remy is easier to swallow than Hitachi.
JohnG(TX)
09-28-2007 10:44:59
OK, now I am thinking about the Hitachi alternator. It looks like it will fit on the original mount with a 3/8" bolt.
Janicholson
09-28-2007 12:29:45
 Re: Farmall Super C Alternator in reply to JohnG(TX), 09-28-2007 10:44:59
Go with the Hitachi, The size difference, and tidy install make the difference for me, and the country of origin for good technology is irrelevant. Wiring setup will be in the archives. JimN
