706 narrow front to wide front
Placer
09-17-2007 11:09:23
I am buying a 706D with a narrow front. I want a wide front and the guy I am buying it from has an 806 he has been parting out with a wide front. Can this be switched out and if so, how much of a project is this?
Thanks,
John
Lee in Iowa
09-17-2007 20:53:45
 Re: 706 narrow front to wide front in reply to Placer, 09-17-2007 11:09:23
My neighbor made a thing that helps a lot for mounting wide fronts. It clamps to the wish bone shaped bar on the back of the wide front and a bar goes down to two old lawn mower wheels. This arrangement holds up the back end of the wide front and allows you to roll it under the tractor and maneuver it into position to get the bolts in. Lee
ejr-IA.
09-17-2007 12:55:01
It would be a direct bolt on.A matter of good jacks and blocking with extra help to aling and bolt in place.Clean all the threads in the front bolster four too clean out.A wide front is a handfull to wrestle with when not attached too the tractor some type of hoist would be nice.
