1066 front end parts
Rickyp
08-16-2007 19:41:48
I need to order some parts for the front end of my tractor. Can someone send me a parts list for the front end. I need to know if there is a bushing on the pin in the steering cylinder. Thanks, Ricky
MN Scott
08-17-2007 06:03:25
 Re: 1066 front end parts in reply to Rickyp, 08-16-2007 19:41:48
Go to CIH's online parts website. Most tractors since 1939 are listed there. Click on "launch Messicks Case/New Holland Parts Catalog" on the middle of the web page below.
Brownie450
08-17-2007 05:20:38
If you are talking about the 1" pin on the left side, We replaced it with a tapered stud with a locknut top & bottom. Our "independent" repairman got it for us---don't know if it was IH or some jobber had them. He had a taper drill bit to drill into the front axle just enough to form a seat for the tapered stud. Locknut top & bottom, & no more trouble. You might check with IH to see if they have something yet. The steering cylinder itself has 2 bushings--1 on top--1 on bottom--kind of pricey as I recall.
wgatewood
08-17-2007 06:30:43
 Re: 1066 front end parts in reply to Brownie450, 08-17-2007 05:20:38
i have totaly rebuilt 4 of the 66 series front ends. give easy bob's tractor parts a call he can help you his # is 765-675-2530 and he ships and takes credit cards.
