Order Farmall Cub Parts Online
getting overhauled Cub engine to start
Farmallb
08-11-2007 18:24:27
Engine turns over 90 miles an hr, but wont pick up and start. Put in around 2 teaspoons of auto trans fluid in each piston to seat up the rings, It started running down through the carb. Flooded new plugs, and will get some more. Let it set for 2 days for the oil to seat up. With new rod caps the piston rises up enough to press in the point on the plugs. Is that right?? Ive heard of having to use 2 rings in the plugs to beat that problem. Engine worked before overhaul, just lost power/
El Toro
08-12-2007 12:02:54
 Re: getting overhauled Cub engine to start in reply to Farmallb, 08-11-2007 18:24:27
third party image
Did you remove any of these gears during the engine rebuild? Hal
El Toro
08-11-2007 16:45:55
Did you measure the ring gap on the new rings before installing them on the pistons? I would bring No1 piston to TDC on the compression stroke
and then look at the valves on No1 cylinder to see if both are closed. This will determine if the valve timing is off. Hal
Janicholson
08-11-2007 08:03:47
Do a compression check, I think (with oil getting back down to the intake, that there may be valve adjustment, or timing issues. JimN
Patrick Martin
08-11-2007 06:48:58
If you are getting fire and you have it timed correctly (or pretty close) then it should fire or at least sputter.
If you are not getting any sputtering at least then for sure you have a valve issue and your not getting any compression.
Do a compression and leakdown test. If you are getting no compression then loosen your valvetrain. No or weak compresion equals no combustion..... no start.
Patrick Martin
08-11-2007 06:51:13
 Re: getting overhauled Cub engine to start in reply to Patrick Martin, 08-11-2007 06:48:58
Oh yeah forgot to say, the pistons shouldn't ever touch the plugs. Be sure you have the right size plugs. If you do then add a ring.
