Inherited an F-30
Glenn in Indian
07-30-2007 05:10:40
An elderly relative saw my 2 restored Cases and offered me his 1939 F-30 for free. Good news--- It’s been stored inside for 35 years, tires are up and decent-looking, Front and rear wheels are round-spoked and rims are good---old tractor is pretty straight all over. Bad news--- engine is apart, sleeves out and hanging on the gearshift and belt pulley levers. I couldn’t see, but I can’t imagine that the crankshaft is usable after being exposed all these years.
1. Are complete rebuild kits available with new sleeves/pistons, and if so, does anybody have an idea as to how much these cost? I have a feeling I could get in pretty deep on a “free” tractor.
2. I know there weren’t anywhere near as many F-30s made as there were F-20s--- is a decently restored F-30 worth much more than decently restored F-20?
steelfronts
07-30-2007 15:14:59
 Re: Inherited an F-30 in reply to Glenn in Indiana, 07-30-2007 05:10:40
Glenn All the parts you need are out there somewhere and your feeling about getting in too deep on a free tractor is warranted if you insist on new parts However an F30 will be worth half again as much as an F20 and they are a real forgiving engine. If its not going to be asked to work much any part thatss not broken will most likely do.
F-Dean
07-30-2007 08:12:17
No need for an expensive rebuild kit. If it was inside, you should be able to hone the cyclinders, buy new rings from Rice Equipment (814) 226-9200, have the head re-ground and put her back together. The F-30 like the F-20 is a rather simple tractor. If you have any problems, post here and you will get plenty of good advice. Good Luck
russ hamm
07-30-2007 05:27:52
I think you will probably be okay cleaning up that crank. Being apart is sure better than together and stuck. Good luck and i think you are fortunate, enjoy the f-30. Lots of power on those.
jal-SD
07-30-2007 06:05:31
 Re: Inherited an F-30 in reply to russ hamm, 07-30-2007 05:27:52
That tranny & rear end must be bullet proof. Back in the mid-70's, there used to be a guy from Nebraska that came up to SD for the hot rod tractor pull our Jaycee chapter had on the 4th of July-he had an F-30 w/440 Chrysler engine in it. It never seemed to bother that old F-30's rear gears that all that HP was in front of it. (My $0.02 worth. jal-SD)
russ hamm
07-30-2007 06:56:57
 Re: Inherited an F-30 in reply to jal-SD, 07-30-2007 06:05:31
You guys saw right. There were many that pulled hot rod back then. Even multiple engines, those trans and rears were bulletproof.
georgeky
07-30-2007 06:13:46
I know a guy here in KY that had one with a 383 in it. Some how he had a 2 speed power glide tranny rigged between it and the tractor tranny. While back I saw a 44 MH with a 4 cylinder GM engine and a bull dog tranny in it. That thing would run 50 MPH and had a 4 speed PTO. I wish I had bought it, he just wanted 500 for it and other than that engine rigging it was a nice 44.
