PTO lever locked up on farmall 230
Dan in MO
07-22-2007 19:06:30
Was mowing without problems until I stopped. When I tried to engage the PTO lever it would not move. I looked and there seemed to be enough fluid, guess I need to know where can I get an exploded view of this part so I can work on it. Any help is greatly appreciated
Dan in MO
07-25-2007 03:13:02
 Re: PTO lever locked up on farmall 230 in reply to Dan in MO, 07-22-2007 19:06:30
Thanks to everyone just what I needed. Dan
Hugh MacKay
07-23-2007 02:40:23
Dan: These are quite simple and you have two possible problems unless something is broken up. First, about 2" back from the pto engage lever is plug with blade type screw end. Behind that plug is a spring and detent device that is designed to hold pto lever either engaged or disengaged.
Secondly the actual engagment happens as a result of a hollow shaft sliding on a solid shaft. That hollow shaft is designed so it actually only makes contact with the solid shaft at both ends. If you know or suspect the tractor was parked for extended period, years for example. Rust can build up during that non use as no oil gets up there during that non use. This applies to both sliding shaft as well as the detent.
Usually this is just a matter of removing PTO and doing a clean up. Find a spot to park tractor with front wheels about 1' below rears, then you don't need to drain the transmission. Just remove the bolts around the PTO housing and it will slide right out. If it has a belt pulley, best to remove that gear box first, keeps weight and balance a bit better. Don't misplace or loose shims between the two gear boxes.
GA Dave
07-22-2007 20:18:26
OK Dan, finally got my $#!+ together. The 230 PTO is shown under attachments. The exploded view is identical to the 240 also. Sorry for my confusion but I'm trying to quit smoking after 48 years. First day and only had two. Maybe one or none tomorrow. I,ve been taking one 1MG Chantix for a week while still smoking and started taking two yesterday. David.
GA Dave.
07-22-2007 19:41:17
I checked the CaseIH site and did not see the exploded view for the 230 PTO. Search 240 as it shows it. Seems the 200, 230 and 240 shared some of the same parts? David.
Kevin Meier
07-22-2007 19:17:49
have you looked in the cnh website? Link
GA Dave
07-22-2007 19:15:09
CaseIH.com. You can print out exploded views and part numbers. David
