1949 farmall c lifters
dougie94
07-14-2007 15:57:30
I just picked up a 49 C.I took off the valve cover and saw two rods out from under the rockers.What happened?Did I lose a pump in them and what should I do.The tractor sat for 12 years.
Dan(Mass)
07-14-2007 17:33:57
 Re: 1949 farmall c lifters in reply to dougie94, 07-14-2007 15:57:30
Hi, Your valves are stuck open. If you look at the springs they will be shorter than the others. Because they are compressed. If you soak them with trans fluid or use some PB Blaster over time you may be able to free them up. In the worst cast you'll need to remove the head. Like Hal said make sure your rods aren't bent.
El Toro
07-14-2007 16:09:57
The valves may be stuck. I would pull the head
and I would check those push rods to see if they are bent. These are solid lifters in this engine
and the valve clearance has to be set with a feeler gauge. Hal
