3pt hitch IH 404/444
Tyler Mostia
02-13-2007 19:35:52
will the 3pt hitch off a an International 404 fit on an International 444, and where do they get the hydraulic fluid from i am going to convert a Ih 3444 backhoe loader into a tractor with a 3pt, any info would be great, thanks
Tyler Mostia
02-14-2007 21:41:48
 Re: 3pt hitch IH 404/444 in reply to Tyler Mostia, 02-13-2007 19:35:52
great, that is just the information i was looking for, what i meant about the oil thing, is, the oil that raises the lift up and down is there a pump built into the 3pt unit or does it run off a pump in front of the crankshaft, or does it use the power steering pump, thanks again.
Fromjb2
02-14-2007 15:59:25
Hi Tyler, as Hugh said the 444 is UK built and belongs to the B275,B414,434,444,384 family of tractors. The B250 belonged to the same family but the early versions had a different 3pt hitch than the above.
Find a scrap yard with one of the above.
Good luck
JimB
Hugh MacKay
02-14-2007 02:22:47
Tyler: Tw0 completely different tractors 404 was a US built chassis and the 444 was British built chassis.
JayWalt
02-13-2007 21:20:40
u can get the hydraulic fluid from caseih. advanced auto also sells a hytran spec compliant fluid for $33, and autozone sells just a generalfluid for $25 5 gallons of course. not sure what it costs at case.
As for the hitch fitting, i have no idea
georgeky
02-13-2007 21:11:00
Tyler, I am not sure but I dont think they will interchange. These two tractors are quite different. The 404 is baisicly a modern version of a Super C . Someone here will know more about it than I do. I did have a 444 for 2 years and rearend is different than my 404. I think the444 draws oil from rearend housing, but could be wrong about that to.
