d361 info
d361
01-18-2007 17:50:08
i have a d361 in a 560 farmall and like to put a turbo on it what would be the best kind and size to use also how big of a roosamaster pump could i use thinkin using one with a 450 head on it
ejr-IA.
01-19-2007 09:59:42
 Re: d361 info in reply to d361, 01-18-2007 17:50:08
A 390 head and 429cid injectors would work for plenty of power.A M&W turbo off a 806 should work also.
Nat 2
01-19-2007 05:10:46
If you really and truly have a D361, then a turbo off a 1206, or 1256, or maybe a 1456 should be a bolt-on affair, and put more horsepower into the rear end of that poor 560 can possibly handle.
Same goes for the injector pump. One off of a 1256 should give you as much pressure as you realistically would want to put through the engine and have it last.
