51 C Farmall
Thumbanger
12-25-2006 14:48:02
I have 51 C Farmall Runs great. Go to put it in gear it grinds some time. You can kill tractor put it in gear mash clutch start engine perfect start to let out on clutch grinding starts let out all the way off and running.Until you go to stop mash clutch starts to grind until you take it out of gear any help please. Thanks
gene bender
12-26-2006 06:17:55
 Re: 51 C Farmall in reply to Thumbanger, 12-25-2006 14:48:02
could also be oil slinger gear as they can sure make weird noises
Janicholson
12-26-2006 06:26:28
 Re: 51 C Farmall in reply to gene bender, 12-26-2006 06:17:55
Gene would not the oilslinger be spinning (thrashing around) only when the input shaft was turning? From what I'm reading, it makes noise when in gear and clutch down. Also has difficulty slowing trans while clutch is down. (Just thinking out loud), JimN
Janicholson
12-26-2006 04:58:45
I have been thinking about the H noise some more and will add to the previous post that the Pilot bearng in the flywheel is also a high level suspect if the noise goes away with the trans in N and the clutch either in out, but is there with the clutch in with the trans in gear. The pilot bearing only spins when the clutch is is, and the shaft is not turning. JimN
Thumbanger
12-25-2006 15:25:05
Thanks Jim you have helped on lots of problems hope you had a Merry Christmas
Janicholson
12-25-2006 15:26:13
 Re: 51 C Farmall in reply to Thumbanger, 12-25-2006 15:25:05
Still going on!!! JimN
Thumbanger
12-25-2006 15:08:13
Hello Jim free play is 1 inch once you get going things are good pulls fine mash that clutch to stop it will raise H until you take it out of gear,
Janicholson
12-25-2006 15:20:25
 Re: 51 C Farmall in reply to Thumbanger, 12-25-2006 15:08:13
If the noise stops when you take it out of gear, and the clutch is let out then the only thing is the TO bearing. If it stops making noise even when the clutch is in and it is out of gear, the springs and components of the driven disk in the clutch may be out to lunch. The drive hub and tortion springs may be falling apart. Which happens:
Stops when out of gear clutch out
Stops when out of gear clutch in
JimN
Janicholson
12-25-2006 14:56:40
Sounds like a throw out bearing. Is it safe to say the noise is not happening when the clutch is all the way released (foot off the pedal)? If so I believe it may be the TO bearing, or fingers on the Pressure plate. Tell us more, what is the free play like, should be about an inch. JimN
