Order Farmall Cub Parts Online
what's all the pipe plugs for on a cub TC?
M clunker
12-22-2006 19:42:10
I was out tinkering with my new cub today and was wondering what the 1/8 inch pipe plugs are for on the left side of the resovior under the filler plug.There are 3 or 4 then there is one on the right side close to the bottom.Then there is a bigger plug(about the size of the fill plug) between the tank and light switch? I tried looking overat the cub site but the I couldn't find anything in the manuals.I don't know if it matters but mine is a 72INT. cub. thanks guys!
Jim Becker
12-24-2006 08:48:42
 Re: what's all the pipe plugs for on a cub TC? in reply to M clunker, 12-22-2006 19:42:10
The one low on the right is the drain plug. There is one on the head (from the back side) that gives access to the orifice and screen that may need cleaning if it gets plugged. The other plugs are as Harold said and don't require any particular attention for normal maintenance.
Harold Hubbard
12-23-2006 03:29:47
If it's anything like the Touch Control on the C, Super C etc. the block has a lot of internal oil passages. These all had to be drilled through from the outside, and then were plugged when the drilling was finished. The C engine is the same, there is a row of plugs along the block where they drilled the oil passages to the main bearings.
