Factory wide front (M)
RIPPER
12-17-2006 20:01:32
How do the support rods hook up to the frame, are they bent slightly outwards to the frame with tension, or do they end up at the frame when put in? Now the story...I bought a factory wide front from a guy and he told me it was for an M but the steering knuckle and spindles are diff. and when I went to install the support rods they end up at the oilpan and have to be bent outward to the frame to drill my holes for the bolts. Is this right or is there a diff. in the width in an M and H factoy wide front????
Much help needed!!!!! !!
Thanks
dave in mn
12-25-2006 12:29:49
 Re: Factory wide front (M) in reply to RIPPER, 12-17-2006 20:01:32
It almost sounds like you got one for an H instead of an M. The center steering arm for the H had a smaller bolt pattern than an M and the frame rails were narrower on the H. Both front ends used H wheels with the smaller bearings though.
IaGary
12-18-2006 04:20:26
Ripper
If you go to Mikes CA post up above there is a picture of how it belongs in the link to the ebay ad.
Maybe looking at the picture will help.
I think you need to spin the rods where they attach to the front mounting bracket.
Gary
