Swapping parts between a 560D and a MD
Brad in WI
11-21-2006 12:02:25
I saw a post about putting a motor from a MD in a 560D chassis. Can I take the fast hitch off of my dead 60D and mount it somehow on my MD. Would be nice to have some lift on the back but it is not necessary. How many parts are interchangable between the two rearends.
third party image
third party image
third party image
I cannot look at both tractors at the same time as the MD is 45 miles from me right now and the 560D is 110 miles from me at my uncles house. Thanks for all ideas.
jack in wis.
11-22-2006 04:13:41
 Re: Swapping parts between a 560D and a MD in reply to Brad in WI, 11-21-2006 12:02:25
drop me a line with your number. im east of green bay. don't need the hitch.
Brad in WI
11-22-2006 09:56:40
 Re: Swapping parts between a 560D and a MD in reply to jack in wis., 11-22-2006 04:13:41
Jack,
I tried to send an email to you but it said there was a problem with one of the email addresses. try to send me one and I will get back to you
wegman in Mn
11-21-2006 20:21:54
I started that post. sell ot to me see if my dad will buy it for me. 1000 where you located? been looking for one like my neighbors nf good cond.also been looking a worthington ag parts for whole salvage
Brad in WI
11-22-2006 02:30:55
 Re: Swapping parts between a 560D and a MD in reply to wegman in Mn, 11-21-2006 20:21:54
I am in Green Bay WI but the tractor is in Norway Michigan. about 100 miles north of Green Bay. I thought about mating the 560 tranny to the MD engine and use the MD tinwork. Just thinking out loud for now.
Ross Provine
11-21-2006 19:45:13
Brad does your MD have duals on it or is it just the angle of the picture? Ross
Brad in WI
11-22-2006 02:38:04
 Re: Swapping parts between a 560D and a MD in reply to Ross Provine, 11-21-2006 19:45:13
yes it has duals on it. I have since removed them but still have all of the components to put them back on. It is very wide with the duals on or very narrow with the outer tires off. Here is some more pics of the duals
third party image
third party image
third party image
Wardner
11-21-2006 16:57:35
A fast hitch could be put on your pickup or, God forbid, a John Deere. It's a matter of how well you work with metal and your imagination. I probably own the only 650 with a fast hitch. It is extra rugged with side plates carved from 1" plates. It has two IH 3.5" cylinders. It can be quickly converted to 3pth. It is cobbled together with parts from a 560, 706, and misc junk from my pile. I don't think these pictures will help you much, but follow D Slater's advice and look at the bolts that hold on your axle housings. Attach your fabricated side plates there. The pivot for the wishbone will attach to the M swinging draw bar mounting holes. Good luck.
third party image
third party image
third party image
jack in wis.
11-21-2006 16:06:47
how much do you want for what is left of 560?
Brad in WI
11-22-2006 02:28:39
 Re: Swapping parts between a 560D and a MD in reply to jack in wis., 11-21-2006 16:06:47
Jack, what parts do you want. I have everything except the wide front that was on it. The diesel engine is stuck very bad. Let me know what you need and I may work a deal with you.
Brad
Hugh MacKay
11-21-2006 14:55:20
Brad: Your MD chassis is not drilled for fast hitch, nor is it exactly the same shape. The easy fix would be put the 560 rear chassis under the MD. You'd have to go all the way to clutch housing to get a match, but look what you'd gain; fast hitch, IPTO and live hydraulics if you don't already have live hydraulics.
Putting the MD sheet metal on there would no worse than building an HTA. Would make one unique MD, might even be a MDTA.
D Slater
11-21-2006 13:13:00
It can be done, but brackets need to be fabricated to bolt to axle housing bolts and then bolt to hitch mounts. Looks like the lift links are fabricated on your fast hitch.
