ih weight amounts
garry lee
11-20-2006 12:50:49
i want to get some full round and some half weights that came off a famall M. they have two spots to grab as handles, and four holes towards the middle and four "slots" on the outside, i'm assuming to hook more up. does anyone know the amount of weight of these? i also want to get some half weights, do they weigh half of what the full round ones do?
thanks
Garry
Randy in NE
11-20-2006 13:36:06
 Re: ih weight amounts in reply to garry lee, 11-20-2006 12:50:49
The full weights weigh about 145 lbs. The half weights are about 1/2 each. The holes and slots and set up so that you can mount the first weight and secure it using the inner set of holes. Then you can add additional weights using the slots/holes around the outside of the weight. They are set up to use square headed bolts and then they won't turn in the holes.
