'53 Super A
Lane R
10-22-2006 18:03:15
I am proud to say that I am the new owner of my uncle's 1953 Super A. It looks like a piece of junk (there is no surface without rust on it) but it means a lot to us, so we are going to go all ahead full with the restoration. But I do have a question. After the serial number, there is a suffix of JA. Does anyone know what this suffix stands for?
Thanks,
Lane
CNKS
10-23-2006 07:00:18
 Re: '53 Super A in reply to Lane R, 10-22-2006 18:03:15
As noted J means Rockford clutch, A is distillate, not kerosene, if that matters. Kerosene is B. The same "A" code may follow the serial on the engine also. Top right of block under #1 spark plug.
Marty Goodier
10-23-2006 06:24:33
I have a 53 Super A also, I have a book called Letter series Farmalls It will tell alot of great stuff. Check your locale book store.
RedJohn-2
10-22-2006 20:02:16
Lane, Not sure but I think J means Rockford clutch; A means kerosene burning engine.
RedJohn-2
10-22-2006 20:11:08
 Re: '53 Super A in reply to RedJohn-2, 10-22-2006 20:02:16
Lane, Another thought....does your tractor have a starting gasoline tank with extra hole in hood for the starting gas cap, all-fuel exhaust manifold, shutters? Of course some of these items may have been removed sometime earlier but if any are present you probably have a "fuel burner".
Bill Geer
10-22-2006 18:32:10
Idid not find suffix jA but I did find suffix x1A witch stands for gasoline,low speed gears.
some one will chime in if I'am wrong.
banjo
10-22-2006 18:57:18
 Re: '53 Super A in reply to Bill Geer, 10-22-2006 18:32:10
that's all i could find also.
