FARMALL 100 HYDRAULICS QUESTION
NICK D
10-16-2006 09:21:28
Is there some way to hook up an external hydraulic cylinder into the hydraulic system of a Farmall 100? I have seen some type of by-pass block on Ebay but don't know for sure if this is what it was for or where to hook it up. Any thoughts are appreciated.
gene bender
10-16-2006 18:46:17
 Re: FARMALL 100 HYDRAULICS QUESTION in reply to NICK D, 10-16-2006 09:21:28
You can take out the two plugs that are in the bracket that bolts to the rockshaft assy. The small one is pressure and the big one is return.
City-Boy McCoy
10-16-2006 17:10:13
There is a section on this in the Super A operator's manual - also the 140 manual, I believe. I have not seen a 100 operator's manual, so can't say for sure about it, but I would guess it also has it.
mike
Hugh MacKay
10-16-2006 11:06:09
Nick: There is a junction block that bolts between the touch control unit and the manifold pipe from the pump. From that you can hook on a remote valve. You can buy new ones from Saginaw County Tractor. They can probably supply you with the remote valve to match. Probably even complete directions on hookup.
Nick D
10-16-2006 11:45:04
 Re: FARMALL 100 HYDRAULICS QUESTION in reply to Hugh MacKay, 10-16-2006 11:06:09
Thank you. I appreciate the information.
