Zenith carb pros HELP!
EZ
10-05-2006 18:18:16
I have Zenith carb body. Found in a yard sale. It fits Farmall 130 manifold.
There is a brass button on top with the following numbers stamped on it.
L63A around the outer portion of the button.
12188F closer to the center of button.
Do these numbers make sense to anyone?
Could this be used on a 130 if a kit was put in?
Thanks.
EZ
10-07-2006 10:13:00
 Re: Zenith carb pros HELP! in reply to EZ, 10-05-2006 18:18:16
Found it!
Carburetor listed for Wisconsin AGN 12.5 gas engine. Walk behind tractors, tillers, etc...
Takes same carb kit as 366462R91.
Cool.
Zenith kit K2034
EZ
10-07-2006 10:32:08
 Re: Zenith carb pros HELP! in reply to EZ, 10-07-2006 10:13:00
Sorry,
That K2034 may or may not fit. That is a Zenith number good for Model 68-7 carb.
The carb on the 130 is a 68X7 and takes YT part #BK123V. These are carb kits I'm talking.
Hugh MacKay
10-06-2006 03:27:45
Ed: I'm not a carb pro, however I have had my 130 carb apart 6 times in one day getting the float set right without directions. The information I have is that several different Zenith carbs were used on 100, 130, 200 and 230 tractors. Sometime after daylight comes to SW ON, I will check my own tractor plus a couple others, for those numbers. I'll send an e mail on my findings. I have an e mail to you started in drafts anyhow, think snow blade.
