info on 140
Mark Andersen
09-17-2006 20:09:29
I recently pruchased a farmall 140 with belly
mower. it had a dead battery, but jump started fine. i was wondering if this tractor was a positive or negative ground- not sure. the battery seems to drain within a week, and i thought the battery may be hooked up backwards since it was owned by a company and they had replaced it before the sale, maybe the guy did not hook it up correctly. the serial number is 26015, is there any place to get any info on this tractor from this. thanks for any help.
Mark Andersen
09-19-2006 13:39:25
 Re: info on 140 in reply to Mark Andersen, 09-17-2006 20:09:29
thanks for the info it is a 6 volt system. forgot to mention that.
Hugh MacKay
09-18-2006 03:43:01
Mark: If your tractor is still 6 volt, get an original 140 operator's manual, they contain excellent wiring diagrams. 6 volt batteries have 3 caps for checking liquid, 12 volt have 6 or none.
If it is a 12 volt alternator conversion, go to Bob M's diagrams. Pick the one for distributor Ign. You obviously have something not quite right and is draining your battery. Don't be afraid to ask Bob, he loves to get his teeth into these.
To get advice on here first we must figure out exactly what you have.
tn terry t
09-17-2006 20:18:35
your 140 is a 1964 it should be positive ground 6 volt system which could have been converted to 12 volt negitive groung
tn terry t
09-17-2006 20:17:24
