What is this on my '46 H?
Mike CA
08-15-2006 22:04:16
third party image
On the left side, under the axel and sticking forward. I haven't a clue.
Brownie 45
08-17-2006 07:51:59
 Re: What is this on my '46 H? in reply to Mike CA, 08-15-2006 22:04:16
Could be a lifting link for something like a rope wick bar or some other chemical application apparatus[ sprayer boom]. Looks like something a dumb farmer would rig up anyways.
Mike CA
08-16-2006 07:39:11
So are you guys telling me it's junk, or you don't know?
steve from mo - dangit!
08-16-2006 06:59:01
 Mower lift. in reply to Mike CA, 08-15-2006 22:04:16
Not all of it is there, but that mower lift uses a cultivator cylinder. That cylinder is for the front of a four-row cultivator. The shaft from the cylinder is inside a piece of pipe that is on the end of the cylinder. The cylinder is extended, and probably the rest of the lift is gone.
Harley
08-16-2006 06:51:13
Guys, does it look like that cylinder is extended and then the shaft is rusted? Probably start leaking if it was pulled back into the cylinder. That shaft is supposed to be chromed and shiny and clean so the seal don't leak. Harley
RustyFarmall
08-16-2006 07:27:13
 Re: What is this on my '46 H? in reply to Harley, 08-16-2006 06:51:13
Harley, I noticed the rust also. It's my guess that the cylinder is nothing more than scrap iron.
Allan In NE
08-16-2006 08:04:06
 Re: What is this on my '46 H? in reply to RustyFarmall, 08-16-2006 07:27:13
Guys,
The actual "ram" is hidden inside the pipe that attaches to the cylinder. It is only about 3/4" in diameter. These cylinders had two "pipes"; an outer and an inner.
That outer pipe on the cylinder doesn't move, but gave the whole works laterial stability when it was inserted into the forward tube. The forward pipe is a necessary part of the assembly tho and mounts (and usually stays) with the implement.
My guess is that this tractor had a belly mount mower at one time and the owner just bolted the lift assembly up to that torque tube when the mower was removed.
Allan
F-Dean
08-16-2006 05:11:24
Ron is right. I need a piece like that for my mower on my M. E-mail me a price or something you need that wee can trade.
Ron Penrod
08-16-2006 04:24:17
If I remember correctly it is used to lift the mower bar on the solid mount sicle bar mower
Mikey D
08-16-2006 02:21:55
Man, I got "no-I-deer". (That's southern talk.) Mike, just never seen anything like that before. mike
Ron in Nebr
08-15-2006 22:23:53
Well, that's a hydraulic cylinder. Not sure what it's doing there. What's the back side of it hooked to? Something solid like the drawbar? Or is it hanging free? If it's free it was probably used on some attachement(but that front mount doesn't look too sturdy). If it's hooked to something solid in back like the drawbar, it's supposed to move that link it's attached to in front, but someone else is gonna have to tell ya what it is.....been 20yrs since we got rid of our H and I don't remember anything there that was supposed ta move....
Mike CA
08-15-2006 22:30:12
 Re: What is this on my '46 H? in reply to Ron in Nebr, 08-15-2006 22:23:53
hmmm. I don't have a picture that shows it from the back. The rear pics I have show the drawbar, but you can't see in front of it. The tractor is 4 hours away, so I can't go see it.
Ron in Nebr
08-15-2006 22:34:50
 Re: What is this on my '46 H? in reply to Mike CA, 08-15-2006 22:30:12
Well, from the looks of it, I'd say it about has to be intended to move that peice it's attached to on the front of the small shaft....moves something inside the bellhousing/tourque tube area. But like I said I don't remember anything like that on the H I used to run(it was a Super). I'd bet good money though that somebody on here will know exactly what it is!
