Super A with Exhaust Lift
Mick Oz
08-10-2006 16:10:58
I've been offered what I think is a Super A. But it has not run for a year or so,apparently the Magneto does not work. Is their a way I can test the magneto or it's parts to see what it's problem may be?. I've only worked on cars and a Fergy TE20 before so I need some advice even if the advice is don't but it!
CNKS
08-10-2006 17:18:08
 Re: Super A with Exhaust Lift in reply to Mick Oz, 08-10-2006 16:10:58
The Super A did not have an exhaust lift, the A did. If it has a large cylinder connected to the exhaust manifold it is an A. If it has two small levers next to the throttle, a reservoir under the gas tank, and a hydraulic pump below the distributer or mag it is a Super A.
Nebraska Cowman
08-10-2006 16:48:05
Clean the points and it will spark again.
third party image
