Changing Hy Tran ???
J Muehring
08-04-2006 03:34:54
Drained water and old oil from farmall 400 trans/diff and replaced with hytran. It shure looks thin but main question is how does proper amount of oil get all the way up to the front of the transmission. I added oil at deck in the little hole by shifter. Thanks.
jossette
08-05-2006 18:17:22
 Re: Changing Hy Tran ??? in reply to J Muehring, 08-04-2006 03:34:54
I would have put 5 gallons of diesel in it first and ran it down the road to clean it out good. Then let it drip dry for a while then put new in.
Janicholson
08-04-2006 13:32:19
After running it for an hour or so (not under load, check the level again. The cases are interconnected. JimN
