Clockwise/counter clockwise
Elk Farmer
07-11-2006 18:11:09
Farmall H. Does the engine run clockwise or counter clockwise? I know the mag runs clockwise so the engine must. RIGHT??
Thanks
F-Dean
07-12-2006 07:56:16
 Re: Clockwise/counter clockwise in reply to Elk Farmer, 07-11-2006 18:11:09
Check the hand crank mechanism. There is only one direction that you can crank it.
CNKS
07-11-2006 19:40:37
The engine turns clockwise when viewed from the front. The distributer/mag turns clockwise when viewed from the rear. So the distributer and engine turn in opposite directions.
Andy Martin
07-11-2006 19:01:15
If you've ever hand cranked an engine you'll remember you lift the crnk with your right hand. Clockwise.
Facing the PTO it turns the same way, clockwise as viewed from the rear. I think this is because the first PTO equipment was actually hooked to the front of engines.
K.B.-826
07-11-2006 18:23:54
The crankshaft will be turning clockwise, when standing in front of the engine and facing it. Mostly all engines are like this, but there are a few that turn counterclockwise.
