Magneto Ground
parkjnl
06-05-2006 20:15:19
Where does the wire for the mag ground mount, on a '46 A w/ the H4 mag? I can't find a terminal anywhere on the magneto.
Nebraska Kirk
06-05-2006 20:45:07
 Re: Magneto Ground in reply to parkjnl, 06-05-2006 20:15:19
third party image
I have circled the terminal in this picture. The brass nut has a threaded hole all the way through it, you just attach the wire with a spade terminal and a small screw to the brass nut. If the brass nut on your mag does not have the hole, unscrew it, drill the existing blind hole all the way through and thread it, I believe it has 8-32 threads.
parkjnl
06-06-2006 16:29:09
 Re: Magneto Ground in reply to Nebraska Kirk, 06-05-2006 20:45:07
Thanks for the info
Pulling the coil was was getting old!!!
