Farmall A governor....I have no throttle!
slydog
06-04-2006 19:53:44
It seems as tho I have very little throttle on my Farmall Super A. When you put the throttle ahead the engine doesn"t speed up until about the last 2 notches on the throttle. What is the problem? Is it very hard to take the governor off and see if I have internal problems? I have tried to do all the adjusments per the manual but to no avail. Any ideas?
gene bender
06-05-2006 03:38:04
 Re: Farmall A governor....I have no throttle! in reply to slydog, 06-04-2006 19:53:44
The gov spring is probably broke.
Shaggy
06-04-2006 22:26:34
My B was doing that this winter and the shaft going to the carb ( out of the governor) was sticking. Try moving it by hand to see if its stuck a little.
Tom Olson
06-04-2006 20:46:05
Happened on my SA too. Went to the local IH dealer and described the symptom. He said it was easy to fix and handed me a new governor spring. I removed the governor housing and sure enough, the spring was broken. Replaced same and has been running just fine since. That must have been 35 years ago.
I & T Shop Service manual has insructions & a pretty good picture.
Tom
