Farmall A Temperature Gauge
kazenza
05-11-2006 06:31:06
Anyone retrofit an A with a temp gauge. The upper pipe to the engine on my 47 A has a threaded hole that looks like it should accept a temperature gauge. The catch on this is that my "A" has a factory installed Super A block. I have the unpressurized thermosyphon system.
Randy, Jamestown
gene bender
05-11-2006 18:46:03
 Re: Farmall A Temperature Gauge in reply to kazenza, 05-11-2006 06:31:06
There is nothing wrong with a temp guage in the upper fitting. These engines will run around 165 whenrunning and warmed up real good.
Super A
05-11-2006 08:36:53
There is a port in the lower pipe going from the block to the radiator. That is where the sensor for the temp. gauge was supposed to go.
Al
MACE
05-11-2006 08:13:36
Hey,
I put a guage on my 1941 gas A and it never moves. They just dont seem to get hot enough when working. It's nice to have just in case.
MACE
Paul in Mich
05-11-2006 07:25:52
Randy, There"s nothing to say you can"t install a temperature gauge, but with a thermal-syphon system, you really don"t need it unless you are burning Kerosene or distillate fuel. The gauge was installed on those tractors so that the operator could monitor and adjust the temperature by opening and closing the shutters.
