Hole in bottom of carb.
W4
04-28-2006 18:04:00
For Rusty Farmall and Old. You told Kevin Schumacher on 4-26-06 that a carb should only suck, never blow.After sitting for 6 months this winter ,my W4 would suck and blow out of a small hole just to the rear of the bottom adjusting screw on the bottom of the carb.After shutting the gas off and spinning the moter over for a few minutes,then turning the gas on, the tractor started, and I took my bride of 49 years for a ride.At the time I figured the sucking and blowing was caused by a valve that stuck open for a bit. The W4 worked fine. My "DUMB" question is,"what is that hole in the carb for?".
old
04-28-2006 18:12:50
 Re: Hole in bottom of carb. in reply to W4, 04-28-2006 18:04:00
Well most carbs have a brass screen in that hole. What it is for is if you flood the carb/engine it drains off the essex (sp) gas so it will drain the gas out faster.
W4
04-28-2006 18:27:27
 Re: Hole in bottom of carb. in reply to old, 04-28-2006 18:12:50
Thanks for the answer. Makes sense.It sure stinks up the garage when it "blows". Stirs up my bride also!!
