1066 Steering Cylinder
Michael Sheik
04-20-2006 05:29:06
I was replacing the tie rod end on left side the other day and noted that the steel block with anchor pin on the end of the steering cylinder has approx. 3/32 play between O.D. of pin and I.D. of steel block. I was considering machining the block out and installing a bushing but when I cleaned off all the grease and dirt, I can see what looks like a bushing already in there. Was this bushing installed at factory or was this a repair. Actually, kind of glad to see the bushing as I will not have to machine out block. I am also sure there will be some wear on O.D. of shaft. I could build up with powder torch and machine back down but am afraid the heat will make shaft brittle. What do you all think?
One last question! I have not attempted to pull the pin yet. I can see the cotter pin on bottom of shaft but shaft is awfully tight in its hole at present and wandering if it is press fit, screwed in or just rusted in there over time.
Michael Sheik
04-20-2006 09:18:07
 Re: 1066 Steering Cylinder in reply to Michael Sheik, 04-20-2006 05:29:06
Thanks TV! I will get it pulled apart and check my clearances first.
Allan In NE
04-20-2006 05:41:09
Mike,
What I do is just grab the shaft of that steering cylinder and see if you can "shake it" up and down. If there is any slop in there it needs to be repaired.
IH sells a complete bushing/pin kit for that center part of the front end. Seems to me it was something like $65??? (Can't remember).
Allan
Michael Sheik
04-20-2006 05:46:09
 Re: 1066 Steering Cylinder in reply to Allan In NE, 04-20-2006 05:41:09
Yes, you can shake it up and down to where it hits head on top of pin. Real Sloppy! I guess you answered my question in that you said IH sells bushing/pin as a repair set.
the tractor vet
04-20-2006 08:58:24
 Re: 1066 Steering Cylinder in reply to Michael Sheik, 04-20-2006 05:46:09
I would get a rebuild kit and also change the pin in the axel to the new tappered end deal this rtequires you to ream the axel and a special reamer is needed for this i bought the reamer a long time ago and have done a bunch of rebuilds on the 66 seires and 86 seires got one to do here on a rough old 1066 here in a couple weeks .
