706 rear end fluid
Kelly C
04-14-2006 13:52:24
Whats the procedure to replace the hytran in the rear end of a 706. Do you need to drain and fill the axle assemblies seperate?
ejr-IA.
04-14-2006 20:04:49
 Re: 706 rear end fluid in reply to Kelly C, 04-14-2006 13:52:24
6 qt.each and 17 gal. in the diff. housing.
the tractor vet
04-14-2006 15:34:20
Yes there is a plug under each final along with the one for the rear end that is under the drawbar and you fill the rearend thru the trans dipstick and each final has a plug about half way up on the back side of it and they all take Hy Tran
Kelly C
04-14-2006 15:42:32
 Re: 706 rear end fluid in reply to the tractor vet, 04-14-2006 15:34:20
Thanks Vet.
You know about what the finals hold for fluid?
the tractor vet
04-14-2006 17:52:16
 Re: 706 rear end fluid in reply to Kelly C, 04-14-2006 15:42:32
Not off the top of my head i just fill them till it comes out .
