what would you use?
banjo
04-05-2006 12:32:15
hey fellers, the larger freeze plug on the back of my SA is trying to rust out. would you use the original type or the compression fit?
how much do the compression type stick out? this needs to be flush for the flywheel clearance.Thanks
banjo
04-05-2006 19:31:34
 Re: what would you use? in reply to banjo, 04-05-2006 12:32:15
guess i'll use the oem type. got one on order. one of these days i'll get this ol tractor back together. seems i keep finding things to fix.
the tractor vet
04-05-2006 13:14:23
And OEM style plug will be fine just look how long that one lasted , now you can get a Sainless steel one but that is a bit of over kill.
mbnok
04-05-2006 12:51:26
Takes a little hunting. Get a regular type brass and be done with it.
