hydro 70 and plow
farmallkidinPa
04-02-2006 18:48:02
i work for a local farmer who has a hydro 70 that doesnt get work much and i was wonderin if i could put a 3 bottom fasthitch plow behind it(i figure some plowin will get her cleaned out some). how well would this combo work in light soil and some small hills.
thanks in advance for any info
Quebec Red
04-02-2006 19:33:15
 Re: hydro 70 and plow in reply to farmallkidinPa, 04-02-2006 18:48:02
Used a H70 as prime power for 3 years prior to getting more land. Did an OK job on tillage, but not as good as a gear drive would have. Before going to the field, do a complete maintenance on the tractor. Clean the rad and change the antifreeze and the coolant filter.Doesn't have a coolant filter? Get one on now. Change the hydraulic oil, filter, and the HYDRO filter. Take it easy in the field, watching the temperature. They will do alot of work if properly cared for. I had a total of 7 Hydros, in tractors, combines, and windrowers. Zero major repairs. Biggest was the direction capsules. These were good units, just improperly marketed...QR..
farmallkidinPa
04-03-2006 16:37:52
 Re: hydro 70 and plow in reply to Quebec Red, 04-02-2006 19:33:15
i knew all that stuff that had 2 be done cause if i dont plow with this i have to plow with his hydro 186 and a 3 bottom rollover(but thanks for remindin me cause i wouldnt have remembered if u hadnt said about it). i just wasnt sure how well she would do cause shes never been rebuilt and the help b4 me was a little too easy on maintenance. thanks for such a fast response.
