Super BMD parts????
Eric W
03-09-2006 15:35:16
My neighbor found a super bmd that has been sitting for a long time. One of the cylinder walls is busted, and he is going to try to fix it. We need a sleeve and piston. I'm not sure what bore and I really don't know much about the motor. If anyone knows where we can get parts for this tractor without taking a boat, please help. Eric W, Indiana.
MJ in the UK
03-10-2006 05:36:19
 Re: Super BMD parts???? in reply to Eric W, 03-09-2006 15:35:16
Hi Eric. Nice find is a SUPER BMD Farmall your side of the pond. Built at IH Doncaster works from 1953 to 1958. 4 inch bore indirect injection diesel engine with glowplug starting system. The part number for a piston and liner set is 700784R91. Hope this helps also the B450 tractor uses the same pistons and liners. MJ
gene bender
03-10-2006 04:31:55
Pull the sleeve and piston then you will know more about what you will need by having some measurements.
El Toro
03-09-2006 18:09:12
You should be able to get sleeves from NAPA or
from any Case/IH dealer. The sleeve bore is probably 4.00". This forum has sleeve kits too.
Hal
John M
03-09-2006 17:17:25
Eric,
When I redid a B450,(yes they made those too overseas) I had to have some engine parts like that.I needed all 4 sleeves and rings and was able to reuse my pistons.I found the sleeves at of all places,my local Napa dealer.They werent specific for my B450,but fit perfect.Maybe take a sleeve and piston with you and see what they come up with.Thast what I did.He had some sort of generic ring guide he ordered the rings for but I had to modify them slightly.
FatRedneck
03-09-2006 16:55:31
you gotta make up your mind, is it a super B or a M diesel, never made a super MD so that dont work, and i dont wanna sound stupid so if there really is a Super BMD get a pic on here cause i really wanna see that. when ya find out what it is let me know and i'll try to help!
Here is the Super BMD
03-09-2006 17:09:43
 Re: Super BMD parts???? in reply to FatRedneck, 03-09-2006 16:55:31
Clicky
IaGary
03-09-2006 18:10:27
 Re: Super BMD parts???? in reply to Here is the Super BMD, 03-09-2006 17:09:43
Learned something again today. Never knew they made M's in Britain.
I thought it was in the 70's before production in Britain.
And here.....
03-09-2006 17:13:04
third party image
is a nice example of a Super MD
John M
03-09-2006 17:06:18
Well,its a SUper BRITISH M DIESEL! They made them overseas.
John M
03-09-2006 17:07:04
 Re: Super BMD parts???? in reply to John M, 03-09-2006 17:06:18
Oh and IH did make a Super MD.
IaGary
03-09-2006 16:39:28
I may prove myself stupid for asking this question but--What is a super bmd? I've never heard of one but I know I don't know everything.
Just ask my wife.
Arno
03-16-2006 01:07:11
 Super BMD in reply to IaGary, 03-09-2006 16:39:28
See google and put in Super BMD.I have placed some pictures of my SBMD on ytmag.com Farmall.
Enough to find!
