Trans Oil Change Procedure
Tweeter
02-23-2006 15:31:07
What are the steps for draining the transmission fluid in the IH 330U? I"m guessing if i had an Operator"s manual that would help but I only have Parts and Shop manuals for it. I know it takes 7 gallons of Hy Trans and the fill hole in by shifter. Is there any filters to replace? Are there any tricks to doing it?
Nat 2
02-24-2006 11:21:39
 Re: Trans Oil Change Procedure in reply to Tweeter, 02-23-2006 15:31:07
On that tractor, all you do is drain out through the bottom, then fill in through the top until it runs out the hole in the side...
jossette
02-23-2006 19:00:55
drain it
put 3 to 4 gal of diesel in it
run it down the road 3/4 mile and back
drain and let it drip completely.
put new oil in.
