Order Farmall Cub Parts Online
HOLE IN FARMALL CUB MANIFOLD
NICK D
02-14-2006 09:04:37
I have a Farmall Cub that has what looks like a drilled hole about 3/16" dia. on the bottom side of the exhaust manifold, just above and to the front of the carb. inlet flange. Is this supposed to be there? It looks factory, but makes a black sooty mess of the paint on the carb. and engine block. It doesn't make sense to me.
Janicholson
02-14-2006 10:06:03
 Re: HOLE IN FARMALL CUB MANIFOLD in reply to NICK D, 02-14-2006 09:04:37
Three solutions
Adjust your carb to limit the soot (needed any way)
Thread the hole and put a fitting with a metal tube pointing away from the block
Thread and Plug the hole and use a exhaust pipe rain cap.
JimN
NICK D
02-14-2006 12:20:40
 Re: HOLE IN FARMALL CUB MANIFOLD in reply to Janicholson, 02-14-2006 10:06:03
Thanks. I never noticed it before and wasn't sure.
the tractor vet
02-14-2006 09:26:47
It was put there as a drain for water running down the pipe.
RustyFarmall
02-14-2006 11:12:52
 Re: HOLE IN FARMALL CUB MANIFOLD in reply to the tractor vet, 02-14-2006 09:26:47
Tractor Vet is right, that hole is supposed to be there, don't attempt to plug it. The solution is to start the engine and then make the tractor work for awhile, get the temperature up and keep it there for awhile, and you will burn all of that black gooey stuff out. No more drips.
