sassy 706
Troy Schwartz
02-10-2006 20:12:21
Hi I got the 706 running but have a couple problems..... I pulled the plugs before trying to start it after a 11/2 years and antifreeze come out of 2 cylinders I then put plugs back in and it fired up I run it for a while and checked the oil it was overfull and milky, but the antifreeze wasn,t down any. Then to top it off I went to start it again and it would only stay running when I held the starter button in. Can anybody help !!!!! !!
El Toro
02-11-2006 16:40:32
 Re: sassy 706 in reply to Troy Schwartz, 02-10-2006 20:12:21
You can jumper around a ballast resistor with another wire feeding voltage directly to your coil. Then if the tractor stays running you've found the problem. I would then get a new resistor before using the tractor. Hal
El Toro
02-11-2006 16:34:04
You could have a bad ballast resistor if your tractor is using 12 volts. The ignition switch could be the problem too. You need to check for voltage at your coil with a volt meter with the ignition switch in the on position. Then have someone attempt to start the tractor and then see if the voltage is present when you let off on the starter at the coil. Hal
Aces
02-10-2006 20:21:08
Troy You would have a bad head gasket or crack as for the antifreeze, but the start and run only when you hold the stater button is a electrical problem. Bad resister bad wire on that circuit or loose connection.
