666 lift
MikeinKy
01-17-2006 07:58:14
My 3pt hesitates when I pull the lever back. If I'm plowing and raise the plows, the tractor goes about 10 feet before the lift starts to raise. Also when you lift it any time, if you release the lever it drops toward the down position until it meets whatever position the 3pt is in. You have to hold it until you get it where you want it. Got any ideas?
IH Gary
01-20-2006 18:22:36
 Re: 666 lift in reply to MikeinKy, 01-17-2006 07:58:14
If it takes that long for the hitch to raise the unloading valve is sticking. Next time you try to raise the hitch pull one of the remote valve levers on pressure. If the hitch comes up right a way the unloading valve is sticking. As far as the lever not staying put they were right about the adjustment. If what I told you works email me and I will tell you how to get to the unloading valve
Allan in NE
01-17-2006 10:41:26
Hi Mike,
First your levers. There are two clutches for those levers. Take a 1/2" socket, stick 'er in there from the front bottom of the control housing and tighten 'em up a touch so that they both feel right to you.
Does that draft control lever flop around too? That could be the reason for your hesitation too.
Does the hitch hesitate when it is empty?
Allan
third party image
MikeinKy
01-17-2006 19:39:56
 Re: 666 lift in reply to Allan in NE, 01-17-2006 10:41:26
Thanks Allen, I'll try that. It seems to be slow all the time. I noticed it with my box blade on it too.
