B-414 diesel glow plug resistor
Frank Broucker
01-14-2006 10:54:56
Hi guys, I bought a new resistor and and it seems to work fine. It glows red when switch is on. New glow plugs are on the way. My question is; should I install just one to see if voltage is correct or all four at once. Also , will the system work with one good plug, or do you need all four to be good to create a good ground. Thanks Frank
jb2
01-14-2006 12:43:18
 Re: B-414 diesel glow plug resistor in reply to Frank Broucker, 01-14-2006 10:54:56
Hi Frank, the glow plugs are in series like the old christmas tree lights. If one is burnt out the others wouldn't work but since you replace the indicator and it glows when the switch is on then the glow plugs are not open. Now one time on our B414D we did have a glow plug develop an internal short and it would blowout the glow plugs that were connected before it in the electrical circuit.
JB2
