ih424 stalling
yoda
11-12-2005 15:17:01
I was brush hogging my fields and after about an hour my tractor stating sputtering on and off a little and then stalled. In order to restart it i would have to pull the choke out and if i moved the throtle or tried to put it in gear it would start to stall again. I let it idle for a couple of min. and then drove it around and it ran fine. I am looking for any suggestions of possible causes.
El Toro
11-12-2005 16:38:38
 Re: ih424 stalling in reply to yoda, 11-12-2005 15:17:01
If there's an inline fuel filter between the gas tank and the carburetor, it may be clogged. Hal
El Toro
11-12-2005 15:49:44
I think you may have a blockage in your fuel system. Whenever you need to choke a hot engine
it's a good sign it's starving for fuel. It may be dirt in the gas tank that floats over the outlet to cause the engine to cut out. Check the flow at the carburetor inlet. Hold a container
under the gas line, should have good flow. If this appears ok your carburetor inlet may be plugged, could have a screen. Using that bushhog
requires a lot of fuel to keep the engine running
smoothly. That takes a lot of power too.
Hal
