Farmall A antifreeze
Ram4wd4u
11-02-2005 12:15:39
Can anyone tell me how much antifreeze to add to my 48 Farmall Super A? I am in NJ. It gets cold here but not as cold as some of you experience.
thank you
fenton
11-03-2005 04:49:30
 Re: Farmall A antifreeze in reply to Ram4wd4u, 11-02-2005 12:15:39
Just be a lazy bum like me and buy the pre-mixed stuff they now sell, you can't lose.
NDS
11-02-2005 16:00:21
It is best to premix antifreeze for A it does not have water pump and it takes a long time for thermosyphon system to mix it.
Hugh MacKay
11-03-2005 17:14:55
 Re: Farmall A antifreeze in reply to NDS, 11-02-2005 16:00:21
NDS: I question the slowness of mixing with thermosyphon. Apparently I've been doing it wrong since 1972. Get some -20F temps up here and I have no repaired blocks.
Now I agree it is not going to mix as quickly as with a water pump, but 10 min. at operating temp will do the mix.
Dave BN
11-02-2005 14:45:47
I use store bought distilled water to mix with my antifreeze. Tap water and city water has a lot of chemicals and metals that I don't want in my radiator. Dave.
old
11-02-2005 12:19:35
Do a 50/50 mix and you will be ok almost any where in the world.
RayP(MI)
11-02-2005 16:46:47
 Re: Farmall A antifreeze in reply to old, 11-02-2005 12:19:35
old's advice is good - antifreeze is not just to keep water from freezing - but has anticorrosion additives that need to be in the proper concentration.... Also the advice on mixing it before adding it to tractor is very good. Don't ask how I know.
RayP(MI)
11-02-2005 16:46:22
Ram4wd4u
11-02-2005 12:22:28
Thank you
