300 Utility w/loader Front Tires
Joe Kimbriel
09-12-2005 10:25:21
Well I got the loader on my utility and the second scoop of decomposed granite one of the front tires blew. The tires that are on there are pertty rotten 6.50/16 car or truck tires and I would like to put on the Tri Rib. Is 6.50/16 the correct size and is the Tri Rib the correct tire for this tractor. Joe
Janicholson
09-12-2005 11:52:59
 Re: 300 Utility w/loader Front Tires in reply to Joe Kimbriel, 09-12-2005 10:25:21
Tri-ribbed tires are good for directional control in soil. Most are four ply or four ply rated belted tires. If the work intended is Decomposed Granite, or aggrigate, I would choose a 6 or 8ply rated tire with 5 ribs, or a radial light truck tire (looks aren't everything) again with 6-8ply rating. Keeping them fairly hard 35-40 psi will reduce steering effort on some surfaces, and softer pressures will prove easier to steer on other surfaces. Good luck,
JimN
Nat
09-12-2005 11:38:54
If they're not right, they're right enough... Tractors don't look right with anything but tri-ribs on the front... Get 6 ply rated, 8 if you can find them. Typical 4 ply won't last under a loader, and are only good for show tractors.
Joe Kimbriel
09-12-2005 11:46:11
 Re: 300 Utility w/loader Front Tires in reply to Nat, 09-12-2005 11:38:54
Ok Thanks, I am assuming that 6.50/16 would be right also.
Janicholson
09-12-2005 12:34:38
 Re: 300 Utility w/loader Front Tires in reply to Joe Kimbriel, 09-12-2005 11:46:11
6.50 is good. The 6.50 number may not be found on tires from some suppliers. It might translate into a 195 or 205-78-16 in some brands.
Good hunting
JimN
Joe Kimbriel
09-12-2005 13:09:01
 Re: 300 Utility w/loader Front Tires in reply to Janicholson, 09-12-2005 12:34:38
Thanks again,
